OSE Heavy Duty upgraded 1 piece flex cables for TFL Cheetah
Product ID ose-cable-HD-cheetah-twin
In Stock 2
Price: $79.99
TFL Cheetah 1 Piece Flex cables (Left and Right cable).
OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. The flex cable on these is a thicker gauge for added strength. Installing these cables will make greasing the cables much easier than the stock cables.
No soldering or cutting is required.
NOTE: We can only guarantee this cable works with the TFL Cheetah pn# TFL-1134
Includes:
(1) Left and Right rotation cable with these parts installed.
- Ose-80248 tapered drive dogs
- Octura oc6pnmm prop nuts
- Octura thin nuts
NOTE: See picture 2 for which prop to use with which cable.
A left rotation cable works with left-handed props, for example, prb282027, x442, x447
A right rotation cable works with right-handed props, for example, prb282028, x442R, x447R
Measures:
11.6" (295mm) from end to end
How-To Guides Using This Part
The basics on flex cables
All how-to articles
