OSE Heavy Duty upgraded cable for V1 ProMarine MTR Twin or ProMarine Skater Twin
Product ID ose-cable-HD-pro-twn-v1
In Stock 1
Price: $79.99
OSE upgraded flex cable assembly for ProMarine MTR Twin Drive or ProMarine Skater Twin Drive. These cables work with Version 1 of the ProMarine Hulls. Please see picture 2 for the drives these work with.
These are cut & soldered, ready to install in your boat. No soldering or cutting is required! OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. The wire strands on this cable are a thicker gauge for added strength.
Includes:
(1) ose-cable-1190 Left flex cables with 3/16" (4.76mm) Propeller shaft 2.75" (70mm) Long.
(1) ose-cable-1190 Right flex cables with 3/16" (4.76mm) Propeller shaft 2.75" (70mm) Long.
(2) Octura Thin Nut pn# Oct-n1032
(2) Octura Brass Bullet Nut pn# oc6pnmm
(2) OSE-80248 Drive Dog
NOTE:
Left cable works with left-handed props, for example, prb282027, x442, x447
The right cable works with right-handed props, for example, prb282028, x442R, x447R
How-To Guides Using This Part
The basics on flex cables
All how-to articles
