OSE Heavy Duty upgraded Spartan HD Cable
Product ID ose-cable-HD-spartan
In Stock 1
Price: $39.99
OSE Heavy Duty Flex Cable for the Traxxas Spartan.
NOTE: To work with a Stock Spartan, the cable with need part number ose-83227
OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. The stock cable measures .150" (3.81mm) in diameter. The stock cable will easily break when used on 6s or in a boat that has upgraded the motor for more power. This cable is cut and ready to install in ONLY a Traxxas Spartan that has already been upgraded to accept a 3/16" (4.75mm) propeller shaft.
This requires the purchase of the OSE Spartan Strut upgrade ose-83227
No soldering or cutting required!
This can also be used in any other boat requiring a .187 cable that measures approx. " (mm) from tip to tip.
NOTE: We can only guarantee this cable works with the OSE Spartan Strut, part# ose-83227 . Will not work with the Spartan SR (Self-Righting)
« Previous | Next »
How-To Guides Using This Part
The basics on flex cables
All how-to articles
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
