OSE upgraded flex cable for ProBoat Impulse 31 V1
Product ID ose-cable-impulse31-v1
In Stock 3
Price: $39.99
OSE Flex Cable Assembly for the ProBoat Impulse 31.
 Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands and better alignment with the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting required!
This can also be used in any other boat requiring a .150 cable that measures approx 8 3/8" (212.7mm) from tip to tip.
Includes: Teflon Liner, .150 cable with 3/16" prop shaft and attached drive dog and streamlined bullet nut.
How-To Guides Using This Part
The basics on flex cables
All how-to articles
