OSE upgraded flex cable system for ProBoat Blackjack 24 v1
Product ID ose-cable-system-bj24
In Stock 3
Price: $39.99
OSE Strut and Upgraded flex cable assembly for the ProBoat Blackjack 24 v1 Catamaran (pn# PRB08007)
Includes everything in picture 1.
We have designed a new strut with a few changes.
-Added a replaceable, lead/teflon strut bushing.
-Changed the strut to work with 3/16" prop (4.75mm) shafts. The stock strut is for 5mm shafts.
-Increased the length of the knife edge on the front of the blade.
-Included a bullet nose cone to reduce drag.
Included with this kit is an upgraded US Made .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker wire strands and better aligned to the prop shaft then the stock unit. Which will help vibrations which will help reduce strut bearing wear. Just install it and go!
No soldering or cutting is required!
Includes(All parts in picture 1):
Ose .150" (3.80mm) cable with 3/16"(.187, 4.75mm) propeller shaft.
OSE BJ24 Strut, pn#ose-83382
Octura bushing, pn# oct-oc6ltsb installed into the strut.
Octura slim nut.
Octura Bullet Nut, pn# oct-oc6pnmm
Note:
-Some of the stock Proboat props are a bit smaller than 3/16" and may need to be drilled or filled to fit this system. This system will work with the stock proboat coupler.
-Will not work with the Bj24 V2 part number prb0804942
How-To Guides Using This Part
The basics on flex cables
All how-to articles
OSE Strut for Proboat Black Jack 24 v1
Product ID ose-83382
Price$14.99
Octura Brass Bullet Nut for 3/16" shaft (10-32 thread)
Product ID oct-oc6pnmm
Price$3.79
Octura thin nut for 3/16" shafts with 10-32 thread
Product ID oct-n1032-3pack
Price$2.99
Replacement Motor Coupler for Blackjack 24 & Shockwave 26: 5mm - 4mm
Product ID hh-prb286010
Price$24.99
Octura Sleeve Bushing 3/16" (5 pack)
Product ID oct-oc6ltsb
Price$8.99
