OSE Cable System Upgrade for Traxxas Spartan High Power
Product ID ose-cable-system-spartan
In Stock 0
Price: $59.95
OSE Traxxas Spartan High Power Cable System Upgrade. Will not work with the Spartan SR (Self-Righting)
- Upgrade your Traxxas Spartan to a much stronger 3/16" (.187", 4.75mm) cable and shaft system.
- Works in the stock Traxxas Stuffing tube.
Traxxas built the Spartan with a 5mm propeller shaft and .150 cable. This limits the power you can use. Most increases in power will cause the stock cables to twist and break.
We built this strut in the standard 3/16" size and included two installed lead Teflon bushings (part# oct-oc6ltsb) for added prop shaft support. Then added an oiler/grease fitting for ease of maintenance. This strut is an absolute must for customers running modified motors with their Spartans.
Includes all the parts needed to make the upgrade (everything in picture number 1)
Available in blue anodized aluminum.
Includes:
OSE-83227 Strut with oct-oc6ltsb lead Teflon bushings.
OSE-Spartan-Cable
Oct-oc6pnmm Bullet Nut
OSE-81518 5mm-187 Coupler
1 Product Reviews - Average rating 5 / 5 (Show All)
Well worth the upgrade!
Tyler Key - 30th March 2015
I had broken 3 STOCK flex cables on the stock prop with a neutral strut angle. Everyone was telling me I was doing something wrong but I told them it was designed wrong! I bought this kit from OSE and never looked back again! One of the much needed upgradread more
How-To Guides Using This Part
The basics on flex cables
All how-to articles
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
