OSE upgraded flex cable system for ProBoat Shockwave 26
Product ID ose-cable-system-sw26
In Stock 2
Price: $39.99
OSE Strut and Upgraded flex cable assembly for the Proboat Shockwave 26" Brushless Deep-V RTR PRB08014
Includes everything in picture 1.
We have designed a new strut with a few changes.
-Added a replaceable, lead/teflon strut bushing.
-Changed the strut to work with 3/16" prop (4.75mm) shafts. The stock strut is for 5mm shafts.
Included with this kit is an upgraded US Made .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker wire strands and better aligned to the prop shaft then the stock unit. Which will help vibrations which will help reduce strut bearing wear. Just install it and go!
No soldering or cutting required!
Includes(All parts in picture 1):
Ose .150" (3.80mm) cable with 3/16"(.187, 4.75mm) propeller shaft.
OSE Sw26 Strut pn# ose-83390
Octura slim nut.
Octura Bullet Nut, pn# oct-oc6pnmm
Recommended Prop:
cnc-4214250
Note:
-Some of the stock Proboat props are a bit smaller than 3/16" and may need to be drilled or filled to fit this system. This system will work with the stock proboat coupler.
How-To Guides Using This Part
The basics on flex cables
All how-to articles
CNC Prop 42mm - 3/16 bore
Product ID cnc-4214250
Price$19.95
Replacement Motor Coupler for Blackjack 24 & Shockwave 26: 5mm - 4mm
Product ID hh-prb286010
Price$24.99
