OSE upgraded flex cable for UL-19 Cable
Product ID ose-cable-ul19
In Stock 2
Price: $39.99
OSE Flex Cable Assembly for the ProBoat UL19 hydroplane. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands and better alignment with the prop shaft than the stock unit. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting required!
This can also be used on any other boat that requires a .150 cable.
NOTE: Propeller NOT included.
Includes:
Ose .150(3.80mm) cable with oct-oc6150psL prop shaft 3/16" (.187, 4.75mm).
Drive Dog pn# TFl-518b22
Octura Bullet Nut Pn# oct-oc6pnmm
Octura slim nut.
.150 Teflon
2 Product Reviews - Average rating 5 / 5 (Show All)
Excellent Replacement
Frederick Grassie - 27th June 2022
This is the way to run your UL 19.
Remove the teflon liner, you won't need it. Grease it up and run it.
Very nice compared to stock, but beware
Hawcer - 22nd October 2018
Super straight and smooth running compared to the stock shaft. No adjustments needed, its preset and ready to install.
I strongly recommend replacing the stock coupler and add a .150” shaft saver to the order. My stock coupler was fairly new and I read more
How-To Guides Using This Part
The basics on flex cables
All how-to articles
Flex cable saver .150 or .187"
1 of 3
Product ID ose-80072
Price$2.99
Octura Coupler Flex Hex 5mm to .150 Cable double set screw
Product ID oct-ocfhe5mm15d
Price$14.99
