OSE upgraded flex cable for ProBoat Veles
Product ID ose-cable-veles
In Stock 2
Price: $39.99
OSE Flex Cable Assembly for the ProBoat Veles Catamaran. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker wire strands and better aligned to the prop shaft than the stock unit. The prop shaft is only 2 3/4" (69.5mm) long which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting required!
This can also be used in any other boat requiring a .150 cable that measures 335mm from tip to tip.
We suggest using part number oct-ocfhe5mm15d coupler with this shaft and the ProBoat Veles.
NOTE: Propeller NOT included.
Includes:
Ose .150(3.80mm) cable with 3/16"(.187, 4.75mm) propeller shaft.
Octura Oc6pnmm Bullet Nut
Octura slim nut.
 .150 Teflon
1 Product Reviews - Average rating 5 / 5 (Show All)
Best flex shaft for veles 29
Perry king - 17th April 2021
It’s a very good Quality part I’m running in the 70s and it holds up no problem. I had problems with the stock shaft it might have been a bad part to begin with. it snapped and I lost my prop too. I broke the flex shaft when I adjusted the trim very sread more
How-To Guides Using This Part
The basics on flex cables
All how-to articles
Octura Coupler Flex Hex 5mm to .150 Cable Short Length
Product ID oct-ocfhe5mm15S
Price$14.99
