Labor to solder connectors onto purchased ESC
Product ID ose-custom-solder-esc
In Stock 17
Price: $0.01
If you are purchasing an esc on this order and would like Offshore Electrics solder connectors onto the ESC
- First select the connector size you will need on the "Battery end", see picture above in purple.
Female connector used on the black/negative wire.
Male connector used on the red/positive wire.
- Second select the female sized connector you will need on the "Motor end", see picture above in blue.
IMPORTANT: Keep in mind this may delay your order from 1-3 business days, depending on our backlog of work.
Required:
-This can ONLY be purchased on an order that also includes an ESC on the same order.
NOTES:
- The picture shows an ESC as an sample only. NO esc is included with this purchase.
- The Seaking 180 and Raider 150 ESC already come standard with 6.0mm connectors on the motor end.
- If the customer selects "No work needed on this end " for both the motor and battery end, NO work will be performed!
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
OSE Qs6 Connector to EC5 Series Harness
Product ID ose-qs6-series-ec5
Price$9.99
OSE Qs6 Connector to EC8 Sereis Harness
Product ID ose-qs6-series-ec8
Price$9.99
OSE Raider 150 Esc with Ec5 connectors : Free Shipping
1 of 2
Product ID ose-R-150C-Ec5
Price$69.99
OSE Raider 150 Esc with Qs6 connectors : Free Shipping
1 of 5
Product ID ose-R-150C-Qs6
Price$69.99
XC WT200 ESC 3s-8s - 200 amps : Bluetooth
1 of 7
Product ID xc-wt200
Price$189.99
