OSE EC5 parallel esc to series battery harness
Product ID ose-ec5-para-ser-harness
In Stock 46
Price: $14.99
EC5 Battery Harness for use with 2 esc's and 2 batteries.
In twin motor applications where you are turning laps around a course. Generally, one motor will draw more amps than the other, this will cause an imbalance in the packs.
Using this harness will run the esc's in parallel, so they will drain both batteries at the same rate, then run the batteries in series. Using this will allow use of two batteries with the same ESC's. Doubling the voltage to your esc/motor.
What makes the OSE bullet connectors different than the other lesser expensive connectors on the market? We order our connectors with plating that is much thicker than our overseas competitors. This increases the cost but makes the plating last longer while also reducing resistance.
Includes:
Everything in the picture.
Note: Using this will double the battery voltage of the system it's used in. You must use two battery packs of the same exact specifications, age, and quality. Failure to do so could cause a fire.
