OSE 8.0mm Parallel Harness for ose-qs8p connectors
Product ID ose-qs8-parallel
In Stock 92
Price: $10.99
OSE Parallel Harness with 8 gauge wire for use with ose-qs8p bullet connectors. Using this will allow use of two batteries to double the system MAH but the voltage will be the same.
Made with 8mm bullet connectors with red nylon housing. The included red nylon housing helps stop short circuits.
Includes:
Everything in the picture.
Note:
Because runtime is doubled, its important to monitor heat buildup in the motor, esc and batteries. You must use two battery packs of the same exact specifications, age and quality. Failure to due so could cause a fire.
OSE 8.0mm Series Y Harness for ose-qs8p connectors
Product ID ose-qs8-series
Price$10.99
OSE Charge Lead for OSE Qs8p Connectors
Product ID ose-qs8-chrg
Price$6.95
OSE 8.0mm male/female connector & Red housing
Price$2.49
