OSE 8.0mm Series Y Harness for ose-qs8p connectors
Product ID ose-qs8-series
In Stock 75
Price: $10.99
OSE 8 Gauge Series Y Harness for use with ose-qs8p bullet connectors. Using this will allow use of two batteries with the same ESC. Doubling the voltage to your esc/motor.
Made with 8mm bullet connectors with red nylon housing. The included red nylon housing helps stop short circuits.
Includes:
Everything in the picture.
Note: Using this will double the voltage of the system its used in.You must use two battery packs of the same exact specifications, age and quality. Failure to due so could cause a fire.
OSE 8.0mm Parallel Harness for ose-qs8p connectors
Product ID ose-qs8-parallel
Price$10.99
OSE Charge Lead for OSE Qs8p Connectors
Product ID ose-qs8-chrg
Price$6.95
OSE 8.0mm male/female connector & Red housing
Price$2.49
