J-b Kwik Epoxy : 10 Ounces
Product ID ama-8271
In Stock 0
List Price: $19.99
Price: $16.99
Jb Kwik sets in 6 minutes and is fully hardened in 24 hours.
This product has a quicker set time than the JB Weld but a bit less of a bond rating.
Much thicker than CA glues, this epoxy can be used to glue stuffing tubes, servo mounts, and other larger items that need strong bonding strength.
- Sets In Six Minutes
- Quick six-minute set time lets you complete repairs without waiting around.
- Holds 2424 PSI
- High tensile strength creates a permanent, reliable bond for tough fixes.
- Drill And Sand It
- You can easily shape, tap, file, sand, and drill it after curing.
- Withstands 300 Degrees
- Formulated to handle high-temperature environments up to 300 degrees Fahrenheit.
- Easy 1:1 Mixing
- The simple equal-parts mixing ratio ensures a perfect blend every time.
Specs:
10 ounces
J-b Kwik Epoxy : 2 Ounces
Product ID ama-8276H
Price$7.99
