Adjustable 56mm Motor Mount. This works well in a deep vee / mono style hull. Now features Carbon fiber stands with glue holes in the mount, which adds extra surface area to improve mounting.
Note: Fits motors that are 56mm diameter x 80mm or longer. If your motor has screws outside of the case, check measurements in picture 7.ExamplesLeopard 56mm motors, 5692, 5698 and 56110TP Power v1 motors, Tp5660, TP5670 and TP5680TFL-SSS 56mm Motors The integrated top plate can be used to mount an ESC. All Aluminum construction. Note: Works with water jackets up to 70mm long.Install Note: The center metal section measures 4" wide, so the center two metal parts can be used in hulls with 4" wide rails if needed.
