OSE CNC High Rake Series Props : Stainless Steel
Product ID cnc-HS-xx16
List Price: $59.99
Price: $49.99
OSE HS Series Cleaver 2 Blade Propellers, Machined out of Stainless Steel.
CNC-machined to high tolerances for out-of-the-box use. No modifications are needed.
 OSE CNC High Rake Stainless Steel Propeller Chart
Part Number / SizeDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-HS-421642 mm (1.65")67.202.65"3/16"
cnc-HS-451645 mm (1.77")72.002.83"3/16"
cnc-HS-481648 mm (1.89")76.803.02"3/16"
cnc-HS-521652 mm (2.05")83.203.28"3/16"
Specifications:
  • Pitch ratio: 1.6
  • Blades: 2
  • Material: CNC-machined stainless steel
  • Mounting: Drive dog
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
  • When used with Zonda GT or similar power, these draw high amperage. These are for a few seconds of use for drag-style use. These will push parts hard. If you are worried about burning things up, these are NOT the props for you. Go smaller or stay stock.
OSE CNC High Rake Series Props : Stainless Steel : Reverse Rotation
1 of 2
Product ID cnc-HS-xx16-R
Price$49.99
