Stainless steel CNC propellers. The blade design of this prop lends itself to being a great all-around performance prop, with great balance of top speed, runtime, and takeoff speed out of the whole Machine-cut to high tolerances, this prop is ready to use right out of the box with a razor shaft leading edge.
Specifications:
Pitch ratio: 1.4
Blades: 2
Material: CNC Machined Stainless Steel.
Mounting & Shaft Size: 3/16" (4.75mm) Drive dog.
Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
