CNC De-Tongued Brass Series Props in 1.6 Pitch Ratio. This prop has less blade in the tongue area, which allows for a bit higher rpm for more top speed. But a bit less take-off out of the hole. Machine-cut to high tolerances, this prop is ready to use right out of the box. Machined out of a brass alloy containing copper, zinc, & iron.
Specifications:
Pitch ratio: All 1.6, except 4717, which is 1.7
Blades: 2
Material: Brass alloy containing copper, zinc, and iron
Mounting: Drive dog
Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
