CNC 1.4 Series Props : 4mm bore : 32 to 34mm
Product ID cnc-xx14251-4mm
Price: $19.95
CNC Magnalium 7075 propeller for 4mm prop shaft.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.4 Pitch 2-Blade 4mm Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-3214251-4mm32 mm (1.26")44.81.764 mm
cnc-3414251-4mm34 mm (1.34")47.61.874 mm
Specifications:
  • Pitch ratio: 1.4
  • Blades: 2
  • Material: Magnalium 7075 alloy
  • Mounting & Shaft Size: 4 mm drive dog.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
« Previous | Next »
