CNC Prop 1.4 Pitch Series : Reversed Rotation : 32 to 72mm Props
Product ID cnc-xx1425x-R
In Stock 12
Price: $15.99
Reversed Magnalium 7075 propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 2-Blade Magnalium Propeller Chart - Reverse Rotation
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-3014250-R30 mm (1.18")41.911.65"1/8"
cnc-3214250-R32 mm (1.26")44.701.76"1/8"
cnc-3414250-R34 mm (1.34")47.751.88"1/8"
cnc-3814250-R38 mm (1.50")52.072.05"3/16"
cnc-4014251-R40 mm (1.57")55.882.20"3/16"
cnc-4214250-R42 mm (1.65")58.932.32"3/16"
cnc-4314250-R43 mm (1.69")60.452.38"3/16"
cnc-4514251-R45 mm (1.77")64.012.52"3/16"
cnc-4814250-R48 mm (1.89")67.312.65"3/16"
cnc-5014250-R50 mm (1.97")70.102.76"3/16"
cnc-5214250-R52 mm (2.05")72.902.87"3/16"
cnc-5514250-R55 mm (2.17")76.963.03"3/16"
Specifications:
  • Pitch ratio: All 1.4
  • Blades: 2
  • Material:  Magnalium 7075 alloy
  • Mounting: Drive dog
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
CNC Prop 1.4 Pitch Series : 32 to 72mm Props
Price$15.99
