CNC 3 Blade Prop : 32 to 34mm
Product ID cnc-xx14350-c
Price: $24.95
3 Blade Magnalium 7075 propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.4 Pitch 3-Blade Magnalium Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-321435032 mm (1.26")44.71.761/8"
cnc-361435036 mm (1.42")50.51.991/8"
 Specifications:
  • Pitch ratio: 1.4
  • Blades: 3
  • Material:  Magnalium 7075 alloy
  • H = Hard oxygen-anodized coating for added strength.
  • Mounting: 1/8 " Drive dog, depending on the prop size.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
