3-blade, Magnalium 7075 propeller, 1.8 Pitch in Reverse Rotation. Magnalium 7075 propeller. Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Specifications:
Pitch ratio: 1.8
Blades: 3
Material: Magnalium 7075 alloy
Mounting: 3/16" Drive dog, depending on the prop size.
Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
