These carbon fiber-reinforced props are light, sharp, and don't need balancing or sharpening! NOTE: These are reverse rotation. Looking at the transom, these props spin clockwise. These are screw-on style to fit 4mm threaded shafts.
Specifications:
Pitch ratio: 1.4
Blades: 2
Material: Carbon-fiber-reinforced plastic
Mounting: Drive dog
Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
