OSE upgraded AquaCraft Revolt Cable
Product ID ose-cable-revolt
In Stock 4
Price: $39.99
OSE Flex Cable Assembly for the AquaCraft Revolt Mono. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands and better alignment with the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting required!
This can also be used in any other boat requiring a .150 cable that measures 7 11/16" (195.25mm) from tip to tip.
Includes:
Ose .150(3.80mm) cable with 3/16"(.187, 4.75mm) propeller shaft.
Octura Oc6pnmm Bullet Nut
Drive Dog
Octura slim nut.
.150 Teflon
Octura Coupler Flex Hex 5mm to .150 Cable Short Length
Product ID oct-ocfhe5mm15S
Price$14.99
