Speedmaster 1" Rudder Assembly
Product ID ros-spdr-013
Price: $44.95
This SpeedMaster rudder assembly is made for large nitro and electric hulls 33" (800mm) or larger. Comes with a built-in water pickup. High-quality CNC-cut aluminum to tight tolerances. The rudder features a breakaway brass screw in the rudder bracket to help minimize damage from the blade hitting an object while driving. Comes with basic mounting screws.
The rudder blade measures 6 1/4" long from top to bottom.
 The rudder blade is 1" wide.
We offer this with 5 different brackets.
-Bracket with 1 1/8" of setback.
-Bracket with 1 5/8" of setback.
-Bracket with 2 1/4" of setback.
-Extended bracket with 4" of setback (pictured).
 -XL bracket with 5" setback.
The setback measurement is from the transom to the front of the rudder blade. We also sell just the rudder blade itself. This can be used as a repair replacement instead of buying the entire rudder assembly.
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Speedmaster rudder water fitting 10-32 thread
Product ID ros-spd-102
Price$2.95
RSX380 FE: Wood Outrigger Kit with Fiberglass Cowl (38" 965mm)
1 of 6
Product ID ml-rsx380
Price$239.99
Speedmaster Bearing Block Extension Bracket for Large Rudders Assembly
1 of 6
Product ID ros-bb-ext-lrg
Price$24.99
Speedmaster Short Transom Bracket for 40/60 Rudder Assemblies
Product ID ros-spdr-019-S
Price$6.99
Tee Bracket for Speedmaster for  Large Rudder Assemblies
1 of 2
Product ID ros-spdr-020-tb
Price$7.95
Linkage Rod Connector for 4-40 Rod
1 of 2
Product ID ose-83106
Price$2.49
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
