Scale Center Mount Rudder : Large sized : Includes linkage Cables tfl-502b75-01
Product ID tfl-502b75
In Stock 4
Price: $69.99
Scale-looking aluminum center mounting rudder. We would suggest this blade length/size for a boat in the 45" (1150mm) to 55" (1400mm) range.
Designed to be used with the tfl-502b75-01 scale-looking hydraulic steering linkage system for a real-looking Offshore Racing style system.
The triangle center mount style works well with catamarans. Includes brass breakaway screw to help minimize damage from the blade hitting an object while driving.
Mounting Bracket Measures:
Width: 32mm (1.26")
Height: 38mm (1.49")
Blade measures:
Top of blade mount to the bottom of blade 150mm.
The leading edge of the blade itself 105mm.
Transom mount to the leading edge of the rudder blade approx 7mm.
Suggested for a boat in the 45" (1150mm) to 55" (1400mm) range.
Includes:
(1) Center Mount Rudder Assembly.
(2) Linkage Cable pn# tfl-502b75-1
Linkage Specs:
Length: 330mm (13")
Requires:
Servo arm and clevis
Note:
Boat not included
5mm Tube Clamp Bracket
1 of 2
Product ID tfl-509B52
Price$4.99
TFL Genesis 56 Catamaran 1420mm Carbon Fiber Stepped Hull Cat W/ Twin 5684 Motor 300A ESC
1 of 6
Product ID tfl-1132-C
Price$2,599.99
Scale style hydraulic linkage cable for tfl-502b75 Center Mount Rudder
1 of 2
Product ID tfl-502b75-1
Price$34.99
