T-Jet Small Jet Drive V2 w/ Reverse Hood
Product ID tfl-B54254
List Price: $139.99
Price: $99.99
This includes an optional aluminum propeller, see picture 2 (a $19.95 Value), instead of the standard plastic prop.
Includes a reverse hood, which if you are familiar with jet drives, allows for reverse. However, to use reverse, you must equip an additional servo to operate the hood.
Includes:
(1) Jet Drive V2 w/ Reverse Hood
(1) **OPTIONAL** SSS 3660 V2 2750Kv Motor(5mm shaft) & water jacket $35.00
(1) Coupler (5mm on Motor Side)
(1) Motor Mount
(1) Servo Tray
(1) Linkage rod
Requires:
(2) Mini Servos: 1 for Left/Right Steering, 1 for Reverse.
      Hitec HS-225 (fits snugly and may require sanding to mount) or
      Hitec hh-5086wp(requires 2 holes drilled into the mount)
(1) Propulsion System
(1) Boat hull
(1) Radio System
Specs:
Length: 200mm (260mm with motor) end to end.
Length inside of boat: Approx 130mm (190mm with motor)
Width: 50mm
Height: 62mm
Propeller: Two Blade CNC prop 29mm pn# cnc-2919250
Grate opening 40mm x 85mm
Suitable for motor diameters can be 28, 29, or 36mm diameter motor. We suggest 20,000 or less total rpm.
**NOTE: Mini Servos in the picture are not included!!**
TFL Jet Boat Bare Hull: White Fiberglass (24" 610mm)
1 of 6
Product ID tfl-1151-01f
Price$229.99
4mm Drive shaft for tfl-b54253 T-Jet Small Jet Drive
1 of 2
Product ID tfl-b54253-04
Price$3.95
T-Jet Small Jet Drive by TFL
1 of 8
Product ID tfl-b54253-a
Price$69.99
Linkage Rod Boots Large
1 of 2
Product ID ose-80454
Price$2.95
Leopard 3650 Motor
Product ID leo-3650
Price$44.95
Leopard 3650 X2 Motor
1 of 4
Product ID leo-3650-X2
Price$59.95
Leopard 3660 X2 Motor
1 of 4
Product ID leo-3660-x2
Price$69.95
SSS 3660 V2 Brushless Motor
Product ID tfl-sss-3660-v2
Price$54.99
Sale - Hitec HS-5086WP Digital Micro Waterproof Metal Gear Top BB
Product ID hh-5086wp
Price$49.99
Hitec HS-225 MG Mighty Mini Metal Gear BB Servo
Product ID hh-hs-225MG
Price$32.99
Hitec HS-225 BB Mighty Mini Ball Bearing Servo
Product ID hh-hs-225BB
Price$20.99
CNC Prop / Impeller : 29mm for TFL Jet Drive tfl-b54253
1 of 3
Product ID cnc-2919250
Price$19.95
CNC Prop / Impeller : 29mm 4 Blade for TFL Jet Drive tfl-b54253
1 of 3
Product ID cnc-2919450
Price$24.95
Stainless steel coupler : 5mm x 4mm for RC boat
1 of 2
Product ID tfl-529b99
Price$7.99
