Speedmaster 1/4" CAT: Extended Strut Assembly: Round Bottom
Product ID ros-SPDS-012-250R
In Stock 5
Price: $44.99
1/4" CAT Strut Assembly Extended Strut: Round Bottom with 1/4 Brass Bushing
These can be used on Hydros, Riggers or Catamarans of 40" or greater. Made from high-quality aluminum, CNC-cut to tight tolerances. These come with a cross-drilled strut bushing for .250 (1/4") prop shafts.
Made in the USA!
You may have seen this strut elsewhere for a lower cost; the difference is OSE packages these with the brass bushing, which most all the other companies out there DO NOT!
Requires:
.250(1/4") Strut requires K&S# 8133 5/16" brass stuffing tube.
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
Speedmaster Bushing 1/4" for Large Struts
Product ID ros-spds-015-bsf
Price$5.95
