Speedmaster Center Mount Dual Pickup Straight Blade
Product ID ros-spdr-012-dusb-tee
In Stock 0
Price: $49.95
This SpeedMaster Center rudder assembly is made for large nitro and electric hulls 35" (900mm) or larger. High quality aluminum, CNC cut to tight tolerances. Comes with two built in water pickups for cooling esc and motor individually. The rudder and features a break away brass screw in the rudder bracket to help minimize damage from the blade hitting a object while driving. Comes with basic mounting screws.
"T" Style mount makes this a great center mount rudder for Catamarans.
The Rudder blade measures 6 1/4" long x 1 1/4" wide.
Rudder blade is setback 1.75" (44.5mm. Setback measurement is from the transom to the front of the rudder blade.
Mounting block measures 1.5" (38mm) Wide x 1.25" (31.8mm) Height.
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Speedmaster rudder water fitting 10-32 thread
Product ID ros-spd-102
Price$2.95
Speedmaster Bearing Block Extension Bracket for Large Rudders Assembly
1 of 6
Product ID ros-bb-ext-lrg
Price$24.99
Linkage Rod Connector for 4-40 Rod
1 of 2
Product ID ose-83106
Price$2.49
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
