Speedmaster Sport 20 Strut
Product ID ros-spds-005
Price: $29.95
This is the Speedmaster Sport 20 Extended Strut.
These can be used on Hydros, Riggers, or Catamarans of 24" or greater. High-quality aluminum, CNC cut to tight tolerances. They come with the cross-drilled strut bushing for a 3/16" prop shaft.
You may have seen this strut elsewhere for a lower cost, the difference is OSE packages these with the bushing which most all the other companies out there DO NOT!
We offer this in four different designs.
Round bottom style with hydro brackets(Picture 1).
Flat bottom style with hydro brackets(Picture 2).
Round bottom style with mono brackets(no picture).
Flat bottom style with mono brackets(no picture).
Made in the USA!
Requires:
K&S # 131 1/4" brass stuffing tube.
The cable system of your choice(3/16" propeller shaft).
Measurements:
Strut barrel length: 63.5mm (2.5")
Top to Bottom: Approx 60mm for the flat bottom (See picture 3) and 63.5mm for the round bottom.
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
RSX310 FE: Wood Outrigger Kit with Fiberglass Cowl (31" 787mm)
1 of 4
Product ID ml-rsx310
Price$199.99
Speedmaster Bushing 3/16" for Sport 20 & 21 Style Strut
Product ID ros-spds-014-bsf
Price$5.95
