Speedmaster 21 Strut : Hydro
Product ID ros-spdss-001
Price: $29.95
This is the Speedmaster 21 Strut with short hydro brackets.
These can also be used on Hydros, Riggers, or Catamarans of 27" or greater. Made of high-quality aluminum, CNC cut to tight tolerances. Also included is a cross-drilled brass strut bushing that will accept 3/16" prop shafts.
We offer this strut with either a flat bottom or round bottom style. Flat bottom can be used to give more transom lift for hydros or riggers that need it. Round bottoms are mostly used for catamarans.
You may have seen this strut elsewhere for a lower cost, the difference is OSE packages these with the bushing which most all the other companies out there DO NOT!
Made in the USA
Requires:
K&S # 131 1/4" brass stuffing tube
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Delta Force Vortex Hydro 24: Bare Hull (24.4" 620mm)
1 of 4
Product ID df-vortex-24
Price$149.99
RSX310 FE: Wood Outrigger Kit with Fiberglass Cowl (31" 787mm)
1 of 4
Product ID ml-rsx310
Price$199.99
Speedmaster Bushing 3/16" for Sport 20 & 21 Style Strut
Product ID ros-spds-014-bsf
Price$5.95
