Speedmaster Stinger Strut
Product ID ros-stinger-str
Price: $39.95
It can be quickly adjusted from positive to negative thrust angles. The bushing is cross-drilled to hold grease for an extra smooth driveline. It is constructed from high-quality aluminum and CNC-machined to tight tolerances. This has often been copied by other manufacturers but has never truly been duplicated.
We offer four sizes:
- SPDSD-2140: Electric/Nitro for 3/16" (.187") propeller shafts.
- SPDSD-6090: Nitro, for 1/4" (.250") propeller shaft.
- SPDSD-G250: Gas for 1/4" (.250") propeller shaft, larger and stronger mounting plate for larger gas-sized boats.
Specs:
Length (All Struts): 82.5mm (3.25")
Mounting bracket for Standard & Nitro Struts
- Height: 43mm (1.69")
- Width: 30mm (1.18")
Mounting bracket for Gas Strut
- Height: 58mm (2.28")
- Width: 38mm (1.49")
Notes:
3/16" size use k&s 8131 1/4" stuffing tube (with no teflon)
1/4" sizes use k&s 8133 5/16" stuffing tube (with no teflon)
3 Product Reviews - Average rating 3.7 / 5 (Show All)
Speedmaster billet precision
Dan D - 10th August 2026
I needed a stinger with a floating bushing or ball?bearing option for a high? power, high? RPM mono build. This unit has handled 42 to 45k RPM without any issues. The machining is clean, alignment is true, and the billet CNC construction is noticeably morread more
Good quality
Jake - 10th November 2025
works great on p class boats (34") and under. small, so can be a pain to make your adjustments when dialing in, but once its set, ive never had an issue.
Good for small boats
Ryan L - 12th April 2025
Blown up 3 of these now. Totals the prop, shaft, rudder blade, transom and stinger each time. Not recommended for high power setups, there is NOT enough support on the stinger barrel for large props and high rpm setups. Going backwards to TFL products.
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
OSE .150 cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150L
Price$32.99
OSE .150 cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150L-xL
Price$32.99
OSE .187 (3/16") cable : drive dog : bullet nut : 3/16" prop shaft : 3.25" long
Product ID ose-cable-187-XL
Price$39.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
Speedmaster Bushing 3/16" for Stinger
Product ID ros-spdsd-187
Price$5.50
Speedmaster Bushing 1/4" for Stinger
Product ID ros-spdsd-250
Price$5.50
