Tenshock Evo 2260 "High Power" Version (40mm x 90.0mm long) :
Discounts Apply !
20% Off Cyber Monday
Product ID ten-evo-2260-HP
List Price: $299.99
Price: $279.99
Evo TS-MI-EVO2260-HP High-Power version: 40x90mm: 6 Pole Motor.
See picture 2 for motor chart
This "High Power" version has a larger 40mm case, which delivers more watts than the standard evo-2260 (38mm) while also making it a more standardized size; it's now easier to find motor mounts and water jackets. See picture 2 for the motor chart* and picture 3 for the diagram.
  •  Powerful 6-pole core design for high torque output.
  • Advanced assembly technology enables more efficient use of space.
  • CNC machined aluminum casing
  • Silver windings for higher efficiency.
  • Powerful sintered neodymium magnets
  • High-torque torque-to-weight ratio.
  • The hand-wound weaving of the winding ensures the motor has excellent electrical characteristics!
  • Includes a free water jacket with an internal water channel to ensure water flows around the motor
  • High-grade bearings
    Specs:
    Magnets: neodymium
    Watts: 7500
    Poles: 6
    Motor Shaft: 5mm
    Shaft Length: 15mm
    Can Measures: 40mm diameter x 89.5mm long
    Weight: 520 Grams
    Mounting Screw diameter required: 3mm
    Bearing size: 5mm x 14mm x 5mm
    Connectors: Required - OSE suggests 6.5mm or 8mm
    Water jacket length: 60mm
    OSE suggests 30,000-40,000 total rpm. These are only guidelines; if you don't know how to choose the correct motor, please consult OSE first or other members of the RC Fast electric boating community, either at a local club or on our OSE Forums.
    * It is important to note that the "Max Amps" value represents the maximum recommended operating current for the motor. It does not indicate the maximum current the motor can draw. For instance, the 1550kv motor has a "Max Amp" rating of 165. This means the motor should not be operated at a current exceeding 165 amps. However, this does not imply that an 180-amp ESC will be compatible with the motor. Instead, the user must select a propeller or gearing that prevents the motor from exceeding its "Max Amp" rating. It is important to note that the 165-amp motor can exceed its rating when pushed beyond its limits for a short period.
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
Fully adjustable 40mm diameter motor mount with carbon stands.
1 of 3
Product ID tfl-523b63
Price$29.99
OSE 6.5mm Bullet Connectors
1 of 2
Product ID ose-6.5mm-bullet
Price$1.99
OSE 8.0mm Bullet Connectors
1 of 2
Product ID ose-8mm-bullet-v2
Price$2.29
Castle Creations HYDRA Cobra 5, 8S, 33.6V ESC, 20A PEAK BEC : Free Shipping on this Item
1 of 3
Product ID cas-010-0182-00
Price$349.99
OSE XL Quick Change Motor Mount for Ten Shock 22 series motors
1 of 6
Product ID ose-83357
Price$34.99
OSE Quick Change 5" Rail Motor Mount for TenShock 40mm Motors
1 of 5
Product ID ose-83415-ten
Price$44.99
Octura Coupler Flex Hex 5mm to 1/4" (.250") Cable
Product ID oct-ocfhe5mm25
Price$22.99
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
Have OSE solder the connectors to a Motor
Product ID ose-custom-solder-motor
Price$24.99
Recently Viewed
Pick up where you left off.
