Tenshock Evo 2880 (53mm x 119mm long)
Product ID ten-evo-2880
Price: $395.99
Evo TS-MI-EVO2880 : 53x119mm: 8 Pole Motor.
Combine this motor with a Castle HV ESC to save $86.00!! $699 for the motor and ESC. Normally $786.99
- See picture 3 for motor chart
  • Powerful 8-pole core design for high torque output.
  •  Advanced assembly technology enables more efficient use of space.
  • CNC-machined aluminum casing
  • Silver-copper wire alloy for super-high efficiency compared to basic copper alloy wire.
  • Powerful sintered neodymium magnets
  • High torque-to-weight ratio.
  • The hand-wound weaving of the winding ensures the motor has excellent electrical characteristics!
  • Includes a free water jacket with an internal water channel to ensure water flows around the motor
  • High-grade bearings
    Specs:
    Magnets: neodymium
    Watts: 16,500
    Poles: 8
    Motor Shaft: 10mm
    Shaft Length: 30mm
    Can Measures: 53mm diameter x 119mm long
    Weight: 1200 Grams
    Mounting Screw diameter required: 4mm
    Front 10*22*6 : Rear 8*19*6
    Connectors: OSE suggests 8mm
    Water Jacket: 80mm in length
    OSE suggests 25,000-45,000 total rpm. These are only guidelines; if you don't know how to pick the right motor, please consult OSE first or other members of the RC Fast electric boating community, either at a local club or on our OSE Forums.
    * It is important to note that the "Max Amps" value represents the maximum recommended operating current for the motor. It does not indicate the maximum current the motor can draw. For instance, the 650kv motor has a "Max Amp" rating of 205. This means the motor should not be operated at a current exceeding 205 amps. However, this does not imply that a 200-amp ESC will be compatible with the motor. Instead, the user must select a propeller or gearing that prevents the motor from exceeding its "Max Amp" rating. It is important to note that the 205-amp motor can exceed the 205-amp limit for a short period when pushed beyond its limits.
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
OSE 8.0mm Bullet Connectors
1 of 2
Product ID ose-8mm-bullet-v2
Price$2.29
Castle Creations HYDRA Cobra 5 HV, 12S, 50.4V ESC, 20A PEAK BEC
1 of 4
Product ID cas-010-0183-00
Price$389.99
OSE Quick Change 5" Rail Motor Mount, for 53mm & 54mm Motor with 6 bolt pattern.
1 of 5
Product ID ose-83403-ten
Price$44.99
TFL 56mm Angled Motor Mount
1 of 3
Product ID tfl-523b82-a
Price$29.99
56mm Motor Mount Aluminum & Carbon
1 of 6
Product ID ose-80974-v3
Price$49.95
10mm to .250 (1/4" 6.35mm) Coupler
Product ID tfl-529b96
Price$14.95
Have OSE solder the connectors to a Motor
Product ID ose-custom-solder-motor
Price$24.99
