TFL Popeye Hydro : ARTR Now comes equipped with Seaking 160 ESC and Larger 4074 SSS V2 2075Kv Motor.This boat comes assembled with all high-quality equipment, including CNC aluminum hardware.Includes: -Fiberglass hull for lightweight and high strength. -Seaking 160 v4 ESC for reliable performance and waterproof. -TFL SSS V2 4074 2075kv Brushless Motor -Water pickup rudder with the kick-up rudder. -Aluminum Strut -Metal 38mm copper propeller. -Propeller shaft 3/16" (4.75mm) diameter. -Flex Cable .187(4.75mm) diameter. -ARTR(almost ready to run). -Fiberglass battery tray Boat Specs: Total length with hardware: 35"(895mm) Hull length: 32" (820mm) Hull width: 14.35" (365mm) Color: Green or Yellow Fiberglass Requires: (1) Standard-size servo for steering (1) 2-Channel Radio System (1) 4s 45c 5000 MAH Lipo pack with EC5.(1) Charger for your battery pack
