TFL Zonda GT-v2 : Carbon fiber : Twin Drive: Seaking 160 v4 ESC : 4082 2000Kv motor : ARTR
Product ID tfl-1133-cf-4082-v2
List Price: $1,299.99
Price: $1,199.99
TFL 41" (1040mm) Zonda Rc Boat, Twin Drive and Carbon fiber.
Now in three different color decal sets, Green, Pink or Purple.
This is the Drag Boat version of the Zonda. Built for high-speed straight-line racing with its Kevlar inlay and 4082-sized motors.
To make this boat even lighter, we include a 6s wiring harness. This harness allows you to run (2) 3s lipo packs that will wire the packs to run 6s to each esc. No other place is building them this way! Or you can unplug the harness and run a 6s lipo pack to each esc.
What makes the OSE Zonda different?
(2) Seaking 160v4, see picture 6.
(2) SSS 4082 V2 2000kv Motors, see picture 6.
(1) Set of Left and Right TFL One Piece Cables
(1) Set of metal CNC Left and Right Props
(4) Thru-hull water pickups, see picture 5.
(2) Carbon Battery Slides, see picture 7.
(1) OSE EC5 parallel esc to series battery harness, see picture 11.
TFL built this boat out of carbon fiber for it to be both super strong and very lightweight. Both are very important if you're trying to make a fast electric RC boat. This boat comes assembled with all high-quality equipment, including CNC aluminum hardware.
Some of the major components include,
Carbon fiber hull for lightweight and super strength.
Two Seaking v4 160 ESCs for performance and waterproofing for reliability.
Two TFL SSS
4082 v2 2000kv Brushless Motors for over 6 Horsepower.
Adjustable twin struts for fine-tuning.
CNC left and right counter-rotating propellers.
ARTR (almost ready to run). It requires a servo, a 2-channel radio, and batteries.
Requires:
(1) Steering Servo - 30kg or stronger
(1) 2-Channel Radio System
(1) Charger
Batteries:
(2) 3s or (2) 6s Lipo packs with EC5 connectors.
Hull Specs:
Material: Carbon Fiber
Length Tips to rudder mounting area: 41" (1040mm)
Length of ridding surface: 36.5" (927mm)
Width at widest point: 11.75" (299mm)
5 Product Reviews - Average rating 4.8 / 5 (Show All)
Great running boat
Ozzy - 12th May 2025
I took this boat out for the first time and was amazed at how smooth it was, turned on a dime. Was not happy with the graphics on the boat, they started peeling off before I even got it in the water. And the fiberglass workmanship is lacking around the poread more
Exceptional quality
DanDamit - 05th August 2024
The build quality from the crew at OSE is top tier.
I was able to fit x2 3S 11,300 mAh 150c packs from SMC in here with a small change to the battery trays. And with the included harness I get roughly 7-8 minutes of runtime under casual running. I upgread more
Bad ass artr boat
Zonda man - 22nd May 2024
I bought this last year when they were in stock. I use my boat for GPS speed runs. It did 115mph with a simple prop change. Make sure to pick up a strong steering servo, 30kg or up. I tried a stock truck servo I had around, it didn't work well.
Beautiful cat!!!
Eric E Klanderud G. - 05th February 2024
This boat came amazing, from the carbon fiber finish to the electronics, water pick-ups and the amazing carbon kevlar on the inside!!!
Can't wait to take it to the lake...
Thanks OSE for an incredible work of art!!!
A total beast of a boat
pedro ramos - 27th January 2024
Great boat, fit n finish is like no other, quality electronics already installed.
This boat is scary fast but at the same time is very stable, it gives you an adrenaline rush for sure!
