Low profile strut 110mm long
Product ID tfl-503b75
In Stock 11
List Price: $39.99
Price: $29.99
The adjustable strut.  Aluminum, CNC cut for square drive flex cable. This can also be used with a standard 1 piece flex cable by removing the prop shaft and using a one-piece cable, for example, ose-cable-1190.
Works well on catamarans with transom overhang.
Measurements, see pictures 4 and 5.
110mm (4.3") in length.
26mm tall x 24mm wide.
Lead teflon bushing for 3/16" (.187", 4.75mm) propeller shaft.
Includes:
(1) Strut
(1) Prop shaft
(1) Bullet Nut, 10mm diameter pn# tfl-518B61
(1) Drive Dog, 10mm diameter pn# ose-80246
Requires:
Square drive Cable pn# Oct-oc6sql-24a
Stuffing tube 1/4"
Or the alternate cable would be pn# ose-cable-1190 for a one-piece cable system.
Octura .187 Left Lay Cable : 24" : One Square End
1 of 2
Product ID oct-oc6sql-24a
Price$6.99
Drive Dog for 3/16 (4.75mm) Prop Shafts : 10mm OD
1 of 2
Product ID ose-80246
Price$2.99
Delta Force 36 Explorer Catamaran Bare Hull (36.75" 934mm)
1 of 7
Product ID df-Cat-36
Price$249.99
