TFL 1 Piece 3/16 (4.75mm) Cable for Zonda 41
Product ID tfl-510b50-1133
List Price: $39.99
Price: $34.99
TFL Zonda one-piece flex cable with 5mm prop nut. This is to replace the 2 piece system that comes stock. Installing this cable will make greasing the cable much easier than the stock cables. Simply loosen the motor couple and the shaft will come out of the back of the boat without having to remove the strut. Some trimming of the cable may need to be done to fit your exact boat.
These can be purchased in single left or right rotation. (See Picture 2)
Specs:
3/16" (.187", 4.75mm) Flex cable soldered to 3/16" (.187", 4.75mm) prop shaft that is 85mm long.
272mm from end to end (+/-2mm)
Slot milled for the drive dog grub screw.
Requires:
Ose-80248 tapered drive dog
NOTE: These can be used most struts that require a 3/16" prop shaft.
How-To Guides Using This Part
The basics on flex cables
All how-to articles
Drive Dog for 3/16" (4.75mm) Prop Shafts : 8mm OD
1 of 2
Product ID tfl-518b22
Price$2.99
Tapered Drive Dog for 3/16" Prop Shafts : 10mm to 8mm OD
1 of 2
Product ID ose-80248
Price$2.99
Aluminum 5mm Bullet Nut : blue, red or silver
1 of 2
Product ID ose-83281
Price$2.99
2mm, 3mm, 4mm or 5mm Stainless Nut : Locking
1 of 4
Product ID mc-94205aXXX
Price$0.30
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler REVERSED THREAD
Product ID ose-81518-R
Price$9.99
TFL 3/16 Thrust Washer : 4.76mm x 10mm x .5mm
Product ID tfl-212b40
Price$0.75
Recently Viewed
Pick up where you left off.
