TFL CNC Floor Water Pickup : Single Inlet
Product ID tfl-521b26xx
Price: $9.99
TFL Thru Hull : Single water pickup. Available in black or silver.
To install these, drill a hole to match the inner circle's diameter to recess the fitting flush with the hull bottom, then use epoxy to glue it into the hull.
Available in two sizes:
- M4 Size:
Width 16mm
Depth 2.5mm
Height 18mm
- M6 Size:
Width 22mm
Depth 2.8mm
Height 22mm
Works with 1/4", 9/32", 6mm or 8mm water tubing.
