TFL Arenson Outdrive with 1/4 (6.35mm) Prop Shaft
Product ID tfl-523b43
In Stock 5
Price: $249.99
New TFL Arenson Drive with 1/4" (6.35mm) Prop Shaft
For detailed specs, see image three. For replacement bearings, etc., see image four.
Specs:
1/4" (6.35mm)
Includes 1.5mm Steering Cable with linkage ends
Square Drive Cable
Length from transom to prop is 130mm
Mounting plate: 54mm wide x 46mm tall
Requires:
(1) 5/16" K&S tube
(1) 11/32" K&S Tube.
(1) 1/4" Square drive cable
(1) 1/4" Teflon Tube
(1) T style servo horn with servo and
NOTE: The teflon needs to be run within a 5/16" K&S tube, Then the 5/16" tube and teflon will be installed inside of the larger 11/32" K&S Tube.
2 Product Reviews - Average rating 5 / 5 (Show All)
Tfl surface drive
Scott Wilson - 02nd February 2023
The surface drive is a very quality piece of hardware.
Steering is done by pull pull cable system
If you purchase one or two I recommend taking the steering and trim hull attaching points apart and use blue lock tite in the ferrule nuts.
Also to pread more
Tfl surface drive
Also to pread more
Octura 1/4 (.250, 6.35mm) Left Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-L-24a
Price$7.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
Octura 1/4 (.250, 6.35mm) Right Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-R-24a
Price$7.99
