Fully adjustable 36mm diameter motor mount with carbon stands.
Product ID tfl-523b58
Price: $29.99
This is for mounting a motor on a flat surface, for example, riggers, cats, and hydros. The higher fiberglass stands allow more clearance for the water jacket. Sliding rear mount allows for many length motors and water jackets.
Fits 36mm diameter motors that are 60mm or longer. For example, Leopard 3660, 3674 brushless Motors.
The angle is adjustable to allow straight alignment with flex cable.
The anodized aluminum mounting plate with extended fiberglass mounting stands to distribute the weight of the motor over a larger area for added strength. The mounting plates have holes drilled in the bottom to allow epoxy to flow into them to make a superior bond to the hull.
Applications:
Fits most 36mm motors that are 60mm or longer.
Requires you to provide motor mounting screws.
Comes with a mount only.
