TFL Mini Scale Outboard
Product ID tfl-B54217b
In Stock 1
Price: $139.99
TFL Scale Outboard with Black Cover
This is the outboard system only.
Includes:
Motor
TFL SSS F450 Outrunner 3000kv
Motor Connectors:  3.5mm
Propeller: 31mm diameter (3114310 3 Blade plastic)
-Outboard Unit:
145mm from the bottom of the skeg to the top of the outboard cover.
The cover is 50mm wide
210 Grams (approx) with a brushless motor.
Drive: 4mm Propeller shaft, requiring drive dog-style propellers.
Fits up to 34mm Prop
Requires:
- Everything besides the outboard unit.
- Suggested ESC: Raider 90 esc. You will have to put the matching connector onto the esc.
- 2s maximum, 40c 2000 to 3000mah lipo pack.
- Propeller for a 4mm prop shaft, with the diameter of the prop depending on the application.
Suggested parts, links below. Check the application for a proper fit before making a purchase.
- (1) tfl-B54203 A standoff bracket may or may not be required. Depends on the application.
- (3) ose-3.5mm-bullet connectors
- (1) ose-80452 linkage boots
- (1) ose-80092 stand-up servo mount
- (1) tfl-519b80-a linkage rods
- (1) standard servo
Notes:
-IMPORTANT
-Recommended for 18 (450mm) -22"(560mm) in the 1 Pound Range.
-This is flex-driven and can only be used with left-rotation (counterclockwise) propellers.
Linkage Rod Boots Medium
1 of 2
Product ID ose-80452
Price$2.95
OSE 3.5mm Bullet Connectors
Product ID ose-3.5mm-bullet
Price$0.89
Power HD 13Kg : Standard size : Metal gear : Digital servo
1 of 4
Product ID pow-lf-13mg
Price$16.99
Power HD 13Kg : Standard size : Waterproof : Metal gear : Digital servo
1 of 3
Product ID pow-lw-13mg
Price$19.99
Servo Mount: Stand Up for Standard Size Servo
1 of 4
Product ID ose-80092
Price$12.95
Bearing 4mm x 9mm x 4mm (2 Pack)
1 of 2
Product ID tfl-557b35-1
Price$3.99
Bearing 4mm x 7mm x 2.5mm Flanged (2/pack)
1 of 2
Product ID tfl-557b36
Price$4.99
Outrunner Brushless Motor
1 of 4
Product ID tfl-F450B-KV3000
Price$22.95
Bearing 4mm x 7mm x 2.5mm : (2/Pack)
1 of 2
Price$3.99
Power HD 15Kg : Standard size : Low Profile : Digital servo : High voltage
1 of 3
Product ID pow-d-15hv
Price$59.99
CNC 32mm Aluminum prop for 4mm prop shaft
Product ID cnc-3214251-4mm
Price$15.95
TFl 31MM : 3 Blade : 31mm
1 of 2
Product ID tfl-3114310
Price$5.99
TFL 4mm Thrust Washer : 4mm x 8mm x .5mm
Product ID tfl-212b35
Price$0.75
Linkage Rod Connector for 2.0mm Rod
1 of 2
Product ID tfl-519B21
Price$2.49
Adjustable standoff mounting bracket for TFL Mini Outboard (pn# fl-B54217b)
1 of 4
Product ID tfl-B54203
Price$29.99
Teflon Liner for TFL Mini Scale Outboard tfl-B54217b
1 of 2
Product ID tfl-212b10
Price$3.99
Teflon Liner for TFL Outboard ose-80980 / tfl-542b20
1 of 2
Product ID tfl-212b15
Price$3.99
Flex Cable for TFL Mini Scale Outboard
Product ID tfl-510b21
Price$12.99
Drive dog for TFL Mini Scale Outboard
Product ID tfl-518b15
Price$2.99
