Aluminum grommet for tubing (2 per pack)
Product ID tfl-alu-gro
List Price: $3.99
Price: $2.99
Aluminum grommets for rubber tubing.
These are used so you can run one piece of tubing from the water pickup to the motor or esc in your boat. These are simple to install, drill a hole and use silicon or epoxy to hold it in. We suggest a body reamer to make the hole.
These are available in 6 sizes, depending on the outer diameter of your tubing.
- For 4.00mm OD tubing
- For 4.60mm OD tubing
- For 6.00mm OD tubing
- For 6.35mm OD tubing : PN# ose-tubing-1/4-clear
- For 6.80mm OD tubing : PN# ose-tubing-9/32-clear
- For 6.80mm OD tubing : PN# tfl-213b25 9/32 blue tubing
- For 7.90mm OD tubing : PN# mo-clr-tub tubing
Installation note: First cut a 45-degree angle on the tubing. Then apply a thin coating of oil on the outside of the tubing. Start the tubing into the hole, then pull the tubing through the grommet from the opposite side with a pair of pliers.
Includes:
(2) Per pack
Material:
Anodized aluminum
Note: The picture of the boat with grommets is for display only. This item only contains (2) grommets.
OSE Dual Pickup Rudder Blade for ProBoat UL-19
Product ID ose-83371
Price$19.95
OSE 8mm od x 4mm id tubing : 3' (900mm) long
1 of 13
Product ID mo-color-tub-8mm
Price$6.99
TFL 9/32 Blue water or fuel tubing
Product ID tfl-213b25-b
Price$4.39
OSE Medium 7/32" Silicone Tubing
Product ID ose-tubing_7-32_clear
Price$3.49
OSE Large 1/4" Silicone Tubing
Product ID ose-tubing_1-4_clear
Price$3.99
OSE Extra Large 9/32" Silicone Tubing
Product ID ose-tubing_9-32_clear
Price$4.49
Dual Pickup Rudder Blade for TFL Genesis 900, Zonda, Popeye, Apparition or ProMarine Skater
1 of 3
Product ID ose-83248
Price$19.99
