CNC M4 Threaded Prop : 38 to 40mm
Product ID tp-cnc-oxx-M4
Price: $14.95
CNC Aluminum prop for M4 Threaded Shaft by TP Power.
These propellers thread onto the propeller shaft. They require a propeller shaft that has M4 threads. Machine-cut to high tolerances for use right out of the box. No need to balance these props. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
CNC 1.4 Pitch 2-Blade 4mm Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
tp-cnc-o38-M440mm (1.57")56.02.20M4 Thread
tp-cnc-o40-M4
42mm (1.65")58.82.31M4 Thread
Specifications:
  • Pitch ratio: 1.4
  • Blades: 2
  • Material: Magnalium 7075 alloy
  • Mounting & Shaft Size: M4 threaded shaft
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
2mm wire drive with 4mm threaded end
1 of 2
Product ID tfl-510B03
Price$7.95
