Zipp Kits JAE 21FE v2: Wood Outrigger Kit (33" 838mm)
Product ID zip-6513
In Stock 2
List Price: $149.99
Price: $119.99
Zippkits 21FE v2 fast electric outrigger kit (33FE) with Cowl & Windshield decal.
This is an updated version of the very popular JAE 21FE v1. It uses the same sponsons but Kippkits has lengthened the tub by 3" and modified the rear ski for better performance.
The kit was also made easier to build and includes more hardware than the previous v1 kits. I
This kit was based on the world-record-holding JAE 21GT nitro outrigger kit. The JAE 21 holds numerous oval and straightaway records.
Designed by IMPBA Hall Of Fame member Rod Geraghty. This hull is the current state-of-the-art for riggers and currently holds the record for the fastest ever 2 laps on a 1/4 mile course. Designed for very low hydrodynamic drag with water shearing and anti-capillary features, this hull is fast, and turns are incredible! This version was optimized for heat racing by Martin Truex, Jr.
-This is considered a full kit, as it includes carbon boom tubes, aluminum boom tube collars, 7075 aluminum turn fin.
-This kit is highly per-fabricated, and assembly is easy, thanks to the 33-page photo-illustrated, step-by-step assembly manual.
-Designed for 4S operation to 6000+ mah, the 33FE will accept smaller (4500 mah) 6S setups as well.
The v2 has a center section big enough for any motor and ESC you want. From 3650 to 4082.
Specifications:
Length: 33 inches
Beam: 20-3/4 inches
Weight: 4.0 to 5.5 pounds
Kit Includes:
-Laser-cut Birch plywood for the entire kit
-CNC machined high-density foam sponson cores
-.093 7075 Aluminum turn fin with mounting hardware
-.125 6061 Aluminum Motor Mount
-Anodized aluminum sponson sleeves (4)
-Carbon Fiber Solid boom tubes (2)
-Aluminum boom tube collars (4)
-Brass tub inserts for boom tubes (2)
-33 Page Photo Illustrated Building and Setup Manual
Requires:
Motor: Any 36 - 40mm inrunner
ESC: Any
Radio: 2-3 channel tx and rx
Servo: Standard Size
Strut: Jae 21 strut
Rudder: Speedmaster mini hydro rudder
 *Picture is of a painted and finished JAE 21FE v2 Rigger. Kit comes in wooden parts that need to be assembled and painted.
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Leopard 4082 & 4082 X2 Motors
1 of 3
Product ID leo-4082
Price$89.95
Z21 Strut for Jae-21
Product ID zip-3495
Price$24.95
5/16 Boom Tube Collars / Clamps (4 per pack)
Product ID zip-3480
Price$7.95
Rudder with water pickup : 70mm Long
1 of 3
Product ID ose-80052
Price$13.95
Solid Carbon Boom Rods 5/16 Inch
Product ID zip-5603
Price$15.99
