Features:
Specs: Ampere Meter: Yes - on main LCD display Battery Balance Connector: XH Balancing Adapter Board Battery Temperature Monitoring: No/Yes - Temperature Sensor (not) included Battery Type: 1-2S LiFe, LiIon, LiPo; 1-2C NiCd, NiMH; 2-12V Pb Cooling Method: Cooling fan DC Output: 100W max AC, 200W DC Discharge: Yes Display: Yes Height: 67mm Input Connector: AC cord, detachable, North American plug Input Voltage: 100-240V AC or 11-18V DC Integrated Balancing: Yes - Internal Balancer & External Adapter Length: 140mm Low Input Voltage Protection: Yes Maximum Charge Rate: 0.1A-10A x 2 Maximum Continuous Discharge Rate: 0.10A-2.0A x 2 Model Memory: No/Yes - # Output Connector: Banana Plug to EC3 Over Current Protection: Yes PC Required: No Peak Detection: Yes Reverse Polarity Protection: Yes Safety Timer: Yes Selectable Charge Rate: Yes - Fixed Rate Short Circuit Protection: Yes Thermal Protection: Yes Voltage Meter: Yes - on main LCD display Weight: 668g Width: 153mm
