Jb Weld sets in 4-6 hours and is fully hardened in 24 hours.
This product has a stronger bond rating than the JB Kwik but a slower cure time.
Much thicker than CA glues, this epoxy can be used to glue stuffing tubes, servo mounts, and other larger items that need strong bonding strength.
- J-B Weld's strongest epoxy is steel reinforced. One square inch of J-BW Weld has enough tensile strength to hold 6220 lbs.
- Durable. Once cured, J-B Weld can be sanded, drilled, painted, and tapped.
- Great for all metals, stone, concrete, and fiberglass. Good for rigid plastic, wood, and ceramic.
- Fuel resistant.
- Easy to use: Dispense equal amounts, mix, and apply.
Specs:
2 ounces
