J-B Weld Epoxy : 10 Ounces
Product ID ama-8281
In Stock 1
List Price: $19.99
Price: $16.99
JB Weld sets in 4-6 hours and is fully hardened in 24 hours.
This product has a stronger bond rating than JB Kwik but a slower cure time. Much thicker than CA glues, this epoxy can be used to glue stuffing tubes, servo mounts, and other larger items that need strong bonding strength.
  •  J-B Weld's strongest epoxy is steel-reinforced.  One square inch of J-BW Weld has sufficient tensile strength to support 6,220 lbs.
  • Durable. Once cured, J-B Weld can be sanded, drilled, painted, and tapped.
  • Great for all metals, stone, concrete, and fiberglass. Good for rigid plastic, wood, and ceramic.
  • Fuel-resistant.
  • Easy to use: Dispense equal amounts, mix, and apply.
    Includes:  (2) 5 oz tubes for 10 ounces total.
J-B Weld Epoxy : 2 Ounces
Product ID ama-8265S
Price$7.99
