» How-To Articles » Which wires to connect to esc?
Published
17th October 2024
When making the connection from the bushless rc motor to a brushless esc, you can't make a damaging mistake.
Start by making sure the batteries are not connected, then connect the three motor wires to the three esc wires.
Once you are all wired and the prop is clear, power up the system. If you find that the motor spins in the opposite direction of what you need when you pull the trigger. Its an easy fix.
Here's what you should do:
- First, disconnect the batteries.
- Next, switch any TWO of the three wires (see picture) that connect the ESC to the motor. This will reverse the rotation direction.
Then retest.
