CNC Prop 40mm 3 BLD - 3/16 bore : high pitch
Product ID cnc-4019350
In Stock 4
Price: $19.95
4019 Magnalium 7075 3 Blade propeller. Higher pitch than the cnc-4014350
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
CNC 7512 Magnalium Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-4019350
40 mm (1.57")75.70
2.98"
3/16"
Specifications:
  • Pitch ratio: 1.9
  • Blades: 3
  • Material: CNC-machined Magnalium 7075.
  • Mounting & Shaft Size: 3/16" (4.75mm) Drive dog.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
